4350
Cevap: Need For Speed: Shift (ÇIKTI) Team Racing Pack yayinlandi (147. sayfa)
16 yıl
EA nın forumunda adamlar bu gibi hataları ve eksiklikleri gözlemleyip istekte bulunmuşlar.
Bugs
- flag girl standing in the middle of car in intro
- wheel/gamepad input lag
- cars randomly start jumping/galloping after a crash
- stock Corvette doesn't work at all
- in certain car battles, Viper won't work
- Murcielago's 5th and 6th gear don't accelerate
- force feedback dies randomly (Logitech Momo; might not be game's fault)
- font size sometimes gets staggered in the loading screens
- in online play, opponent's engine noise is distorted; makes stuttering noise
- reversal of certain tuning slider settings, e.g. under/oversteer
- cars sometimes don't appear correctly in replay mode
- screen occasionally fades to black during the grid sequence; requires race restart
Issues/Annoyances
- NO MOUSE SUPPORT - very hard to precisely pick paint colors or move the camera
- LOADING TIMES - hard drive light is not active past the first couple seconds; takes far too long and seems unnecessary
- car model loading times seem to take longer than they should
- won't save language preference
- automatic login has too many confirmation screens
- car settings reset after switching from simple to advanced tuning mode
- some cars are too bouncy, e.g. Works'd Corvette
- ability to scoop up cars is far too easy
- crash blur/desaturation gets annoying sometimes, would be nice to be able to turn that off or down
- drift physics don't seem to allow you to speed up through a drift
- vinyl texture resolutions are a bit too low
- if you have multiple eligible cars for an event, let it ask you what to use instead of having to exit and choose it beforehand
- in-game wheel doesn't match real wheel input that well
- HUD font color hard to see in some views
Update Suggestions
Online
- server selection/list
- ability to kick people from online and change rules after making lobby
- direct chat (IM-like)
- LAN play
Other
- damage model should allow more parts to fall off/break
- ability to save custom tuning profiles
- inclement weather (rain, thunderstorm, snow - even if it has no affect on traction)
- night racing
- ability to paint more intricate parts of cars, or more individualized to the model
- ability to customize body kits/spoilers
- ability to buy stock cars that you've already Works'd (since you can't sell/de-Works the car)
- free camera in showrooms
- ability to save replays
- carbon fiber option
- ability to paint rims
- ability to change tire appearance
- Bugatti Veyron/Carrera GT spoiler should be dynamic, or at least active
- TrackIR support
- more button customization options
- music imports
16 yıl
Direksiyonla drift yapabilen var mı? Varsa özel bi ayar yaptınız mı?
16 yıl
Nvidia GeForce 8600Gt, Intel Core 2 Duo E4500, 2 GB Ram ile bu oyunu hangi ayarlarda oynarım ?
16 yıl
Orijinalden alıntı: salsakingss
arkadaşlar bu oyunda optimize problemi olduğu kesin gibi çünkü att ile baktığımda oyun sırasında GPU yu %45 , CPU yu ise %73 kullanıyo gözüküyo. yarı yarıya ekran kartımı kullanamıyorum yani...
GPU-Z den baktım ben,ekran kartını %100 kullanıyor nerdeyse.. İşlemciyide %60 civarı falan belki dahada az.
16 yıl
rextr cidden direksiyonda drift asla dedim ben. El freni zaten batmıs hissettiriyor nedense bi alısamadım cok feci kayıyor. Döndürünce öbür tarafa döndürmek düzgün kaydırmak zorlu ama aslında biraz ugrasılsa yapılmıycak gibi değil...
16 yıl
Orijinalden alıntı: St Batuhan
driftte direksiyonu tam kırmayacaksın o zaman drift yapamassın spin atar araç yada toparlayamassın. viraja uygun yerden virip direksiyonu az kıracaksın sonra kökleyeceksin gazı viraj daha keskinleştikçe hafif hafif kıracaksın . ama tam kırmayacaksın bu gibi durumda. anca hızlı girip virajı tam içten alırım diyosan full kırıp dönecen sonra diğer yöne kırıp viraj çıkışı dirft yapacan.
16 yıl
Youtube'dan bir kaç drift videosu izledim de, adamlar arka tekerleğe drift boyuncu patinaj çektiriyolar, sanırım ilk önce bunu yapmayı öğrenmek lazım? Yoksa direksiyonu az yada çok her türlü kırmayı denedim beceremedim.
16 yıl
Orijinalden alıntı: bRk..
Diğer oyunlarda GPU sıcaklık 83 derecelere vururdu, bunda ortalama 55-57 arasında geziniyor. neden acaba? ati driver 9.4 kullanıyorum. bundan olabilir mi acaba? OC yaptım 710 Mhz e çıkardım GPU frekansını(normal 630Mhz) yine de ısınmadı kartım. sorun ne olabilir?
16 yıl
Orijinalden alıntı: nehalem28
unsal
verdıgın ayar ıcın tesekkur ederım gercekten ıse yarıyor
ARKADASLAR BENCE OYUN SIMDI 10 ÜZERİNDEN 10 ALIR HALE GELDİ ARABA MİLİM KAYMIYOR
Rica ederim, klavye ve oyunla ilgili başka gelişmeler bulan arkadaşlarda hemen foruma iletirse sevinirim.
ayrıca kokpitte araç çok daha iyi kontrol ediliyor gibi, gerçi oversteer hikayesi başlı başına oyunu düzeltti benim için
16 yıl
Kokpit kamerasından sağa sola bakabilmek mümkün mü? Mümkünse nasıl bakacağız? Bütün tuşlar, mouse vs. herşeyi denedim bi türlü bulamadım.
16 yıl
Orijinalden alıntı: unsal
CAR GARAGE----> TUNING---Quick Tunning
"Balance" sekmesindeki kaydırma çubuğunu "Oversteering" e dayıyoruz. Evet, oversteering,
söylendiğine göre EA over ve understerringi birbirine karıştırmış, büyük hata deniyor.
Fark inanılmaz, artık altınızda dans eden arabaya elveda diyoruz.
Not: Bu arada bu ayarları garajınıza aldğınız her arabaya uygulamanız gerekiyor. Ayrıca "manufacture race"
lerdeki arablara sadece eğer garajınızda ise bu ayarlar geçerli oluyor. E o kadar olsun, zira oyun artık güzel güzel
oynanabilir durumda...
Kaynak:http://www.gamespot.com/pc/driving/needforspeedshift/show_msgs.php?topic_id=m-1-51436140&pid=957699
Kesinlikle oyunu kurtaran ayar bu :)
Ama bende 0'a getirince bu sefer odun gibi dönmez oldu araba, 20'ye getirince pist rekorları başladı :) Gerçi ben detaylı ayarlardan da baya kasmıştım düzeltmek için yol tutuşu, onların etkisi de olabilir.
Murcielago dehşet bir F1 aracına döndü ama şu an (Hız hariç tabi )
16 yıl
Orijinalden alıntı: venomturk
Num Lock tuşlarındaki 2-4-6-8 tuşları ile.
16 yıl
16 yıl
Orijinalden alıntı: djx
nosu nasıl kullanıcaz
önce arabanı modifiye edip nos takıcaksın, sonra yarışırken de space'e basıp nos açıcaksın
16 yıl
Oyunu Logiteck Momo ile oynayan var mı? Ben titreşim olayını çok yeterli bulmadım ya :( Grid de çok daha iyiydi. Acaba iyi yapamadıklarından mı? Ayarları oyuna bıraktığımda zaten varla yok arası, direksiyon ayarlarına girip ayarları kendin yap diyerek herşeyi full e getirirsem ancak titreşim hissettiriyr kendini oyunda ama yine de çarpmalarda falan hala yok?
16 yıl
Eğer Balance ayarını full Oversteering yaparsanız doğru yol tutuş artar direksiyonda sertleşir ancak Helezonlarıda sertleştireceğinden
araçta sallantı yapacaktır oynarken hiç hoş olmaz ve bazı tümsek gibi yerlerde hakimiyeti zorlaştırıbilir
Her ayarın bi avantajı olduğu gibi birde kötü yanı vardır
16 yıl
Ya arkadaşlar Bi bug mu var ya.Aldıgım bi aracı 44 bin ise biraz modifiye ettikten sonra 190 bine e satıyorum bu nedir ya?
16 yıl
Orijinalden alıntı: Mehmet.Fatih
parayı kırarsın işte
16 yıl
oversteer i dayayınca araba pistten çıkınca toparlanmıyor, dönüşler zayıf kaldı kayma bir nebze azaldıda
16 yıl
Resmen rezalet aklıma dicek başka bişey gelmiyor oyunu bitirdim ama benim için de NFS serisi bitmiştir. bu oyuna 9 puan verenleri hiç anlamıyorum arcede desem oyuna değil araba yerinde durmuyor e similasyon desem (Rfactor, GTR2 LFS vs. gibi) o da değil bazıları similasyon olmuş zor olması normal vs. diyorlar arkadaşlar yapmayın etmeyin hiç mi araba kullanmadınız 50km ile giderken direksiyanu az sağa yada sola çevirince arababa kopar mı yoldan ki bundar standart arabalarda bile olmazken ben BMW M3 kullanma şansına da sahip oldum araba kedi gibi yola yapaşıo gerçekte ama oyunda sadece düz yolda giderken sağa sola kaymaya başlıyor oyununun zor zevkli çekişmeli olmasını istiyosan diğer araçların yapay zekasını sağlam yaparsın kontrolleri bozmazsın bu tamamen işin kolayına kaçmak olur artı evet görsellik gayet güzel ama ben sadece arabalara bakacaksam resimlerini de bulurum netten doya doya bakarım önemli olan o arabayı kullandığı hissini verebilmek maalesef araba ile savaşmaktan bu zevki alamıyoruz... NFS serisini hepimize sevdiren yanları o sokaklarda kurallar olmaksızın gaza sonuna kadar basmamızdı kendi arabalarımızı yapmamızdı şimdi diyeceksiniz NFS daha önceden de pistlerdeydi (örn. NFS hot pursuit) ama NFS serisini bize asıl sevdiren undergraund oyunudur sonra ikincisi hele ki most wanted dan vazgeçemiyorum ondan bi hedefimiz de vardı polislere meydan okuyarak rakibimize adım adım yaklaşıp onu alt ediyoduk ve bunun zevki tartışılmazdı şimdi ne var pistte dönüp duruoruz ne için ??? GRID den ne farkı var arabalar daha fazla görsellik daha iyi sürüş farklı adı GRID 2 olsun o zaman optimizasyona zaten bişi demeye gerek yok herkes yakınıyor...
NFS nin oyun dünyasında ayrı bir yeri vardı ama bunu artık iyice kaybetti bu arabalar ve bu grafik motoru ile most wanted 2 yi yapsalar hiç bişi değiştirmeden emin olun daha zevkli olur... Neyse en azından DIRT 2 geliyor hiç olmazsa bu hayal kırıklığını onunla unutmak istiyorum iyi oyunlar...
