60
Egreat R900 PRO + WIFI (3D Bluray + 3D Bluray ISO Player) +çift hdmi çıkış
13 yıl
Hey Allahına kurban şöyle ürünleri de getirsenize popcornhour kardeşim
Özellikleri:
Top hardware design, PCB proper layout and exquisite work, enable player work stable and efficient; adopt lead-less process, compliance with RoHs standard.
Dual HDMI 1.4 ports ,connect with 3D projector or 2D,3D TV at the same time
Support DVBT(optional)
Built-in 3.5" mobile rack
Build-in SATA BD-ROM
Support 3D movie decode and playback
Support 2D movie convert to 3D image
Support USB 3.0 HOST
Support 24DB antenna wireless WIFI
support built-in power supply
Support USB keyboard and USB mouse
Can play BD ISO and BDMV,Support BDMV(BD1.0) full navigation
BD full navigation: support multi track and multi subtitle switch , chapter selection function etc.
Support 7.1 pass through,Support Dolby True HD,DTS-HD MA,LPCM, Dolby Digital Plus
By forcing upgrades can be achieved between two different brush each firmware
Support USB storage device ,e.g. USB HDD
Support 10/100/1000M
LED panel display.
Powerful online video capabilities, support Tianyi, BesTV, Youku HD, SOHU HD, QQLIVE, ku6, Sina,joy and so on(for Chinese marketing)
Support SAMBA share, support BT download
Support gapless playback: TS, M2TS.
Bookmark function: record the last playback time automatically.
Support previewing subtitle.
Adjust external subtitle at random: size, color, time-lapse, upper or down position.
Support playback according to time seeking: time jump and time scroll two methods.
Support slide show, music background, screen savor, movie preview, movie rating.
Video Files Playback Support BD-ISO, mostly use BD-remux, BD-RE, BDRip and some other ways to produce high-definition audio and video files (extension. TS,. MKV,. AVI, etc.).
Support APE,FALC,OGG,AAC,M4A,WAV,WMA,MP1,MP2,MP3,MPA
Compatible with HTML 5.0 web browser
Support Adobe Flash 6.7.8 playback
Product size: 430*285*70MM
Main Hardware parameters:
CPU:RTD1186DD 750MHz
DDR3 SDRAM: 512MB
NAND FLASH:4G MLC Nand flash
Main output port:
Vedio output ports:
Two HDMI 1080P output ports(V1.4),resolution options:480P、576P、720P@50Hz、720P@60Hz、1080I@50Hz、1080I@60Hz、1080P@50Hz,1080P@60Hz
Y/Pb/Pr, resolution options: 480P、576P、720P@50Hz、720P@60Hz、1080I@50Hz、1080I@60Hz、1080P@50Hz,1080P@60Hz
AV output port(Composite) , 576I@PAL、480I@NTSC
Audio output Ports:
Stereo
Optical and coaxial
Other ports:
USB 2.0 HOST ports x 4
USB 3.0 HOST ports x1
Build-in SATA BD-ROM,
Internal 3.5" mobile rack
Network ports:
10/100/1000M RJ45 port x1, support playback by LAN;
Support USB 802.11n WiFi dongle(recommend RTL8191SU solution);
Built-in MINI_PCI card
File formats
Video Container:
RM/RMVB
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4, RMP4
IFO
DVD-ISO,BD-ISO
MINI BD,BD-9,BD25,RBD,D5,D9,DVD,CD
FLV
swf/(.swf) *
3GP/.3gp
AVS/(.avs)
3D Bluray(DISC/ISO) or Single-File(*.ts/*.m2ts)
Video decode:
MPEG1,VCD1.0/2.0,SVCD(up to1920*1080@30P/60I or 1280*720@60P)
HD MPEG2 MP/HL,ISO,IFO,VOB,TS(up to 1920*1080@30P/60I or 1280*720@60P)
HD MPEG4 SP/ASP,Xvid(up to 1920*1080@30P/60I or 1280*720@60P)
H.264 BP@L3,MP@L4.1,HP@L4.1 (up to 1920*1080@30P/60I or 1280*720@60P)
WMV9,VC-1 AP@L3(up to1920*1080@30P/60I or 1280*720@60P)
DivX3/4/5(up to 1920*1080@30P/60I or 1280*720@60P)
XVID SD/HD(up to 1920*1080@30P/60I or 1280*720@60P)
RM/RMVB 8/9/10(up to 1280*720@30P)
AVS: Jizhum profile @ level 2.0/ 4.0/ 4.2/ 6.0/ 6.2
Audio Container:
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
OGG
APE
FLAC
MKA
WMA (WMA PRO)
Audio decode:
MPEGⅠLayer 1/2/3(2-CH) and MPEGⅡ1/2(Multi-Channel)
LPCM,ADPCM,FLAC,AAC,WAV,OGG
DTS digital+stereo
Dolby Digital
RA1/RA-cook/RA-Lossless
Picture format:
JPEG
BMP
PNG
GIF
TIFF
jps(3D)
mpo(3D)
Subtitle format:
Micro DVD [.sub],
SubRip [.srt],
Sub Station Alpha [.ssa],
Sami [.smi]
idx+sub
PGS embedded subtitle
Menu language:
Standard version: simplified Chinese, traditional Chinese, English, Russian, Spanish, Czech, Dutch, Italian, French, German, Turkish, Hebrew
Subtitle language:
Standard version: simplified Chinese, traditional Chinese, Turkish, Greek, Hebrew, Czech, SE European, Central European, Cyrillic, Western, UTF8
HDD format:
Support FAT32, NTFS, EXT3, HFS
13 yıl
3D projeksiyonu ve 3d tvsi olup ta amfisi 3d olmayanlar gözünüzü açın
hem 3d görüntü hem hd sesler aynı anda böyle bir olay oppoda bile yok (çift hdmi var da isolar ve altyazı muhabbeti sorunlu)
< Bu mesaj bu kişi tarafından değiştirildi sadays -- 25 Mayıs 2012; 15:21:38 >
13 yıl
şöyle bir kablosuz air mouse ak66 diyor yanlış model bulmadıysam yanında aksesuar olarak veriliyor
13 yıl
iyi paradır heralde bu cihaz müthiş bir şeye benziyor..
13 yıl
@Sadays
Bilgilendirme için teşekkürler.
Bir konuyu merak ettim?
"HDD format:
Bu detayda Ext4 neden yok acaba.
bizim nas lar Ext4 ağdan desteklermi ki?
13 yıl
Egreat daha ufak cihazlarına bile adam gibi destek veremiyor. Bu cihaz adamı hasta eder, bir yıl güncelleme beklersin.
13 yıl
alternatifin var mı seko kardeş
13 yıl
Var. Bir adet 3D Bluray oynatıcı + iyi bir medya oynatıcı. Muhtemelen daha ucuza gelecektir.
Egreat yazılım işini düzeltmediği sürece geleceği yok. Zaten o yüzden sürekli yeni model çıkarıp gündemde kalmaya çalışıyor. Bak R6S'in son yazılımında elle tutulur tek bir iyileştirme yapmamışlar. Varsa yoksa saçma sapan Çin kanalları eklemesi, kablosuz bağlantı düzeltmeleri falan. Onlar da ne kadar düzeldi bakmak lazım. Bu kadar güzel donanımı bu yazılımlarla harcıyorlar resmen.
13 yıl
hayır o da alternartif olmaz bu donanım avrsi üst düzey olup ta 3d olmadığı için hd ses alamayanlar için özel bir ürün
bir hdmidan 3d görüntü 1 hdmi'dan hd sesler gönderilebilir ama tabii ki bu teorikte özelde egreatin genelde de realtekin ne yapacağı belli olmaz ikinci hdmidan sinyali 1.3 yapıp tüm 3d olayını berbat da edebilir işin kötüsü test edecek kimse de yok milletin egreate güveni kalmadı yur dışı forumlarda filan tanıtıp geççiyorlar ne inceleme ne test olmuyor maalesef
13 yıl
Türkiye'de varmı acaba bu ürün,güzele benziyor hani.Hazır media player arıyorken bunu alabilirim.
13 yıl
dune çıkarsa ya böyle bir ürün
13 yıl
Orijinalden alıntı: sadays
Ses meselesini anlamadım. Aynı görüntüyü iki ayrı HDMI 1.4 çıkıştan aynı anda veriyor. Bunu sesle ne ilgisi var ? Tek olsa da aynı şeyi yapmayacak mıydı ?
13 yıl
sadece görüntüyü değil ki hd sesleri de aynı anda hdmi'dan veriyor dolayısıyla avr 3d olmadı mı otomatik olarak hd ses çözülürken hdmi 1.3 muhabbetinden görüntü 2dye döner bunda çift hdmi var biriyle görüntüyü 3d projeksiyona veya tvye diğeri ile 3d olmayan avrye gireceksin dolayısıyla hem 3d keyfinden hem hd sesten mahrum kalmayacaksın (diyoruz teoride)
13 yıl
Orijinalden alıntı: marseltalon
ilk mesajıma bakarsan zaten türkiye distribütöründen bu ürünü getirmesini istediğim görünüyor yani el cevap yok
13 yıl
R300 bile W2comp'ta 215 $. Bunun fiyatı en az 300 $ olur, en son 600 TL'ye bağlanır. Kim alacak bu paraya bunu ? Kusursuz bir yazılımı olsa eder ama altyazılardaki UTF8 - Türkçe değiştirme sıkıntısı aynen duruyor, ses olayında da bir gelişme yok.
13 yıl
singingegg de var ama o sitede w2compa göre bir miktar daha pahalı oluyor kim bilir sormak lazım w2compa ya da benim arkadaş bir çin yaparsa getirteyim bari maksat muhabbet olsun
http://www.singingegg.com/electronics/index.php/egreat-r900-pro-hd-media-player-dual-hdmi-1-4-ports-2-4g-air-mouse-wifi.html
13 yıl
Popcorn böyle bi ürün çıkarsa ya...
13 yıl
realtek bu işe girdi bir de çinliler ....ku çıktı ne dune ne de popcornhour bu saatten sonra bir şey çıkarmaz çünkü artık ekmek yedirmezler o tatlı kar dönemi bitti
13 yıl
mesajım bulunsun diye mi yazıyorsunuz
üzerinde kopya da olsa 3d blu-ray diskleri oynatabilen blu-ray sürücü olan çift hdmi çıkışlı dünyanın tek oynatıcısı bu
eleştirebilirsiniz elbette ama bu tek ürüne mahkumsanız eleştir eleştirdiğin kadar tavşan dağa küsmüş dağın haberi olmamış muhabbeti
ayrıca seko92 ile hem bu forumdan hem TF'dan yazışırız yani mesaj biraz samimiyet de kokuyor adam alınmamış size ne oluyor
13 yıl
Evet, bizimkisi fikir alışverişi. Sanırım yanlış anlaşılma oldu.
