Silverstone SST-FP56 Multi Panel Card Reader & USB3.0 Hub
Şehir : #İstanbul
İlan Türü : #Satılık
Kondisyon : #Kullanılmış
2 yıl
1 Silverstone SST-FP56 Multi Panel Card Reader & USB3.0 Hub
Çok iyi durumdaki "Silverstone SST-FP56 Multi-Funcation Panel Card Reader/USB3.0 Hub/Charging Port" satılıktır. Kasanın önünde ki 5.25" porta takılır. Tüm fonksiyonları çalışır durumda iki ayrı renkte ki başlığı ve kasaya takılacak 19PIN USB 3.0 kablasu ile beraber full takımdır.
Product Description
Fits in any 5.25” external drive bay
Full support for SDXC card
Three USB 3.0 and one high speed charging port
Supports two 2.5” hard drive or SSD mounts
Supports standard 19pin USB 3.0 internal connector
Enclosure mterial
SECC
Color
Black with extra white and silver front panel
Operating system support
Windows Vista, Windows 7, Windows 8 (32&64), Mac 10.2.8 or above
Application
5.25” drive bay
Front I/O Ports
3 x USB 3.0 port + 1 x charging port
Interface
USB 3.0 (5Gbps)
Media card support
SD / SDHC / SDXC / Mini SD / Micro SD(T-Flash)(No Card Adapter Required) / MS / MS Duo / MS PRO / MS PRO Duo / MS Micro(M2)(No Card Adapter Required) / MS PRO-HG Duo / MMC / RS MMC / MMC Micro / MMC Mobile / xD / CF (UDMA7)
Dimension
148mm (W) x 42.3mm (H) x 176 mm (D)
*Red charging port supports power charging for all USB devices, but data transfer is supported only for USB 3.0 devices. Blue USB ports support charging and data transfer for all USB devices.
Fiyat : 350 TL Miktar : 1 Sıfır Ürün : Hayır Garantisi Var : Hayır Satıldığı Şehir : İstanbul Kargo Ücreti : Alıcı Öder Kargo Şirketi : Diğer İlan Durum : Satışa Açık
