55 CX için aşağıdaki 2 askıdan birini alayım diyorum. Aralarında şekil haricinde ne gibi bir fark var anlamadım. Yorumu ya da başka önerisi olan var mı? https://www.amazon.com.tr/gp/product/B07DCWGZ9F/ref=ox_sc_act_title_1?smid=A3R1STJ8IVPD99&psc=1 https://www.amazon.com.tr/gp/product/B00UJN4SN8/ref=ox_sc_act_title_2?smid=A3R1STJ8IVPD99&psc=1 |
CX’le kullanmada sorun olmaz o zaman. 6 cm olan yeterlidir, alip geceyim en iyisi. |
Detailed applicable model list : Please check with reference Tab exactly * SW information 1. Improvement 1) Software update contains minor bug fixes 2. Applicable model list OLED48C11LB OLED48C12LA OLED48C14LB OLED48C15LA OLED48C16LA OLED48C17LB OLED48C18LA OLED48C19LA OLED48C1RLA OLED55C11LB OLED55C12LA OLED55C14LB OLED55C15LA OLED55C16LA OLED55C17LB OLED55C18LA OLED55C19LA OLED55C1RLA OLED55G13LA OLED55G16LA OLED55G19LA OLED55G1RLA OLED65C11LB OLED65C12LA OLED65C14LB OLED65C15LA OLED65C16LA OLED65C17LB OLED65C18LA OLED65C19LA OLED65C1RLA OLED65G13LA OLED65G16LA OLED65G19LA OLED65G1RLA OLED65R19LA OLED77C11LB OLED77C12LA OLED77C14LB OLED77C15LA OLED77C16LA OLED77C17LB OLED77C18LA OLED77C19LA OLED77C1RLA OLED77G13LA OLED77G16LA OLED77G19LA OLED77G1RLA OLED83C11LA OLED83C14LA OLED83C17LA OLED83C1RLA 3. Release History [03.10.29] 1. Voice recognition service feature will be updated. 2. Software update contains minor bug fix [03.11.15] 1. Software update contains minor bug fixes [03.11.21] 1. Improved sound noise [03.11.23] 1. Software update contains minor bug fix [03.15.27] The following services will be added to the newly updated version. 1. Game Dashboard is provided for game users through setting button 2. A button that links to other art app in Art gallery app service. 3. No need to change the input for using Facebook Portal *The availability of services may vary depending on the region or TV models [03.15.36] 1. Fixing minor bugs in software [03.15.95] 1. Fixing minor bugs in software [03.20.12] 1. Software update contains minor bug fixes |
Burak bey merhaba; Qned modelinin termin tarihlerini öğrenmek için bugün İzmir'de bir LG mağazasını ziyaret ettim. Mağaza yetkilisi arkadaş Qned serilerinin sene sonunu bulacağını, sorunun ne olduğunu bilmediğini söyledi. Kendisine bunun 120 Hz güncelleme ile mi alakalı olduğunu sordum yalap şalap evet diyip geçiştirdi. Karar verme aşamasındayım, Oled alma hevesime obsesif olmam gem vuruyor o yüzden Qned serilerine yöneldim. Termin ve tahmini fiyatlandırmayı daha net sizden öğrenebileceğim kanısındayım. Yardımcı olursanız sevinirim. İyi ve kolay çalışmalar dilerim. |
![]() ![]() ![]() Hocam merhaba, Hocam o tür mağazalara bu ürünler gelmez ne olduğunu satan arkadaşlar bilmez ![]() Hangi modele bakıyorsunuz siz ürünler geldi şuan kaç müşteriye satışını yaptım ![]() Baktığınız QNED modeli söylerseniz yardımcı olurum size? |
55CX6 TV 'min üzerine Etiasglass marka ekran koruyucu aldım. Ürün biraz ağır TV zarar verir mi? Ekran koruyucu ile kullanan var mı? Evde bebek olduğundan ekrana birşey gelmesin diye böyle bir önlem aldım. Birde ürün çok toz çekiyor elektriklenme çok oluyor. |
Hocam görüntüde bozulma oldumu acaba bi değişiklik oluyormu görüntüde |
OLED TV için eti glass özel üretimi var o acıdan sordum? |
Mağazaya girerken eşime; "iki yıldır forumda takip ettiğim televizyonları göstereceğim sana" diye heyecanlanarak gittim ilgili arkadaş bütün oled hevesimizi kırdı ve Qned belirsizliğine bıraktı bizi... Neyse, Qned99/75 8k, Qned91/75 ve 65 fiyatını merak ediyorum + 3 yıl garanti ile. Özel mesajlara kapalıyım burak bey hem belki buradan yazarsanız diğer arkadaşlara da kolaylık olur. Teşekkür ederim. |
![]() Burak Keskin 0506 620 31 32 Arayın detaylı konuşalım sizin için hangisi uygunsa ![]() |
Nakit olarak ödeme yapacağım, ürüm İzmir'e gelecek. ~ Sizi arayıp, ziyaret etmek zaten şart gibi görünüyor. Fiyat ve detayları bildirdikten sonra mutlaka uğrayacağım. İyi ve kolay çalışmalar dilerim. |
LG 65QNED916PA 22.750 LG 75QNED916PA 31.000 LG 75QNED996PA (8KTV) 41.500 Hocam hangi ürün istersen stoklarımızda şuan için var bilginiz olsun. İyi forumlar. |
İlginiz için teşekkür ederim. |
Cahil olmaktan ziyade mağazadaki uykusundan uyandı diye kızgın olduğunu düşündüm. Cahil demek ağır itham. 1-2 çer çöp yüzünden değil takıntılı olduğumu, septik derecede obsesif olduğumu ve yeni tenolojiyi merak ettiğim için uğradığımı söylemiştim. Buradan takip etmek ile canlı ve yerinde görme deneyimi farklı. Buradan zaten yeteri kadar takip ediyorum. "Benden" derken ? Akıl tutulması yaşayıp yaşamamak kağıt üstündeki teknik veriler ile alakalı olduğunu düşünmüyorum! Fakat bu rakamların bandında seyir eden bir Qned yerine oled şuan için tabiki daha mantıklı. Yada yeni çıktığı için fiyat düşmesini beklemek... |
LCD (her ne kadar mini-led olsada) onunda kendine has sorunları var. Bu hastalık ile teklonoji zıt gider hiçbir şekilde mutlu olamazsınız ben sizi uyarayım. En güzeli bir OLED alıp +3 yıl uzatmalı Burak beyden alıp 5 yıl keyif çekmek. 5 yıl içinde bozulunca tekrar yeni tv alıp garanti yaptırıp devam edersiniz ![]() |
Evet fakat sadece onunla ilgili değil biraz da "acaba" diye düşünmek endişe verir diye düşünüyorum. Biraz hakkaniyetiniz var. Tamam doğrusunuz LAKİN bir televizyonun ömrü beş yıl mıdır sizce? |
Bu mesajda bahsedilenler: @tayaydin
