Konuyu çözdüm. CI modülü çıkartıp TKGS yükledim. Daha sonra CI modülü taktım oldu. |
Teşekkürler, eline emeğine sağlık. |
SW File(Version 03.15.27) Detailed applicable model list : Please check with reference Tab exactly * SW information 1. Improvement The following services will be added to the newly updated version. 1. Game Dashboard is provided for game users through setting button 2. A button that links to other art app in Art gallery app service. 3. No need to change the input for using Facebook Portal *The availability of services may vary depending on the region or TV models 2. Applicable model list OLED83C14LA OLED55C19LA OLED65C19LA OLED48C17LB OLED48C19LA OLED65C17LB OLED65C18LA OLED55C17LB OLED55C18LA OLED48C18LA OLED65C16LA OLED65C14LB OLED48C16LA OLED48C11LB OLED48C14LB OLED48C12LA OLED65C11LB OLED48C15LA OLED65C12LA OLED55C11LB OLED65C15LA OLED48C1RLA OLED55C12LA OLED55C15LA OLED55C16LA OLED65C1RLA OLED55C1RLA OLED83C11LA OLED83C1RLA OLED83C17LA OLED77C17LB OLED77C18LA OLED77C19LA OLED77C11LB OLED77C12LA OLED77C16LA OLED77C15LA OLED77C1RLA OLED77C14LB OLED55C14LB OLED77G19LA OLED55G19LA OLED65G19LA OLED77G16LA OLED55G16LA OLED65G16LA OLED77G13LA OLED77G1RLA OLED55G13LA OLED55G1RLA OLED65G1RLA OLED65G13LA OLED65R19LA 3. Release History [03.10.29] 1. Voice recognition service feature will be updated. 2. Software update contains minor bug fix [03.11.15] 1. Software update contains minor bug fixes [03.11.21] 1. Improved sound noise [03.11.23] 1. Software update contains minor bug fix [03.15.27] The following services will be added to the newly updated version. 1. Game Dashboard is provided for game users through setting button 2. A button that links to other art app in Art gallery app service. 3. No need to change the input for using Facebook Portal *The availability of services may vary depending on the region or TV models
Yeni konu hayırlı olsun. |
Dolby Vision filmlerde Ayarlar-Genel-AI Parlaklık kısmını açın benim tavsiyem. |
< Resime gitmek için tıklayın > < Resime gitmek için tıklayın > < Resime gitmek için tıklayın > |
Kullandığınız model LG nin EN SIKINTILI ve EN KÖTÜ OLED i O kadar çok şikayet aldıki LG 2018 serisinde sub-pixel yapısında değişikliye gidip birçok sorunu çözdü.Tv niz miyadını doldurmuş. Basit bir matematik ile 14K olan blue pixel in ömrü sona yaklaşmış zaten. Bence canınızı hiç sıkmayın yeni nesil OLED alın. 2020 ve 2021 modellerinde ciddi anlamda burn in iyileştirmeleri yapıldı. |
Şimdi sizin tecrübelerinize dayanaraktan OLED almayın yanıyor lafı gerçeği yansıtmıyor çünkü 2021-2020 modellerinde artık tam çözdüler. Mantıken OLED alacak adam 2021 yılında 2021 alacağı için sorun olmayacak. Bizde bekledik acele etmedik teklonojisi otursun panel refine olsun diye yıllarca, bende 7 serisi alaydım başım problemden kurtulmayacaktı biliyorum bunu. |
LG ile görüşüyorum, bana dönüşlerine göre destek isteyebilirim. Yalnız 10bin masraf çıkarıp yarısını isterlerse yaptırmam, gittiği yere kadar bunu kullanıp sonra başka TV alırım. |
Bu başlık iyi olmuş..Bende LG OLED 48c1 almayı düşünüyorum ama şu ekran yanması sorunu beni düşündürüyor. |
Mert hocam emeklerine sağlık, buralar hayırlara vesile olsun. |
Biraz araştırma yaptım, bu seride güç kartı aşırı ısındığı için paneli ortadan başlayarak bozuyormuş, yeni panel taktıranların da ekranları tekrar bozulmuş, hatta LG bu seriyi Korede geri çağırmış. Tüm bu bilgilerle hakem heyetine gideceğim, bakalım ne çıkacak, buradan paylaşırım. |
Aynen, kronik sorunlu cihazlar için destek vermeleri gerekiyor, şansımı deneyeceğim... |
@StreamRolleR , Hocam merhaba, Szice herhangi bir sorun görünüyor mu? Cevaplayabilirseniz sevinirim. < Resime gitmek için tıklayın > |
Hesap bilgilerinizi ve kayıt olurken seçtiğiniz LG bölgesinin Türkiye olduğuna eminseniz yapacak ekstra bir şey yok.
Ev internetinin güvenli aile profili olmadığına emin olun. Bazen onlardan kaynaklı durumlar da olabiliyor.
Cep telefonundan hotspot açıp televizyonu o internete bağlayın.
Ayrıca güncelleme varsa televizyonu son sürüme güncelleyin.
Geçen yıl yaşanan benzer durumda güncelleme sonrası sorun düzelmişti.
İlgili mesaj;
https://forum.donanimhaber.com/mesaj/yonlen/158861587
< Bu mesaj bu kişi tarafından değiştirildi mcgoktug -- 10 Ağustos 2025; 0:5:46 >
Bu mesajda bahsedilenler: @Poyraz29.
