Arkadaslar arduino ve l289p ile motor sürmeye çalışıyorum bunun yanında ayrıca mesafe sensörüyle de kontrolü sağlamaya çalısıyorum. mesefeyi algılayınca geri gidiyor sonra tekrar ileri gidiyor.ama ne yaptıysam motorlar çalısmıyor.simdi kodları paylasacagım sizinle.umarım bi sorun yoktur kartta
const int trigPin = 7; const int echoPin=4; void setup() { Serial.begin(9600); //establish motor direction toggle pins pinMode(12, OUTPUT); //drive motor -- HIGH = forwards and LOW = backwards pinMode(13, OUTPUT); //turn motor -- HIGH = left and LOW = right
//establish motor brake pins pinMode(9, OUTPUT); //brake (disable) the drive motor pinMode(8, OUTPUT); //brake (disable) the turn motor
//Turns brake off for drive motor digitalWrite(9, LOW);
//Turns brake on for turn motor digitalWrite(8, HIGH);
//Sets initial speed of drive motor analogWrite(3, 200);
//Sets initial direction of drive motor digitalWrite(12, HIGH); }
void loop() { // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(trigPin, OUTPUT); digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(5); digitalWrite(trigPin, LOW);
// The same pin is used to read the signal from the PING))): a HIGH // pulse whose duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(echoPin, INPUT); duration = pulseIn(echoPin, HIGH);
// convert the time into a distance inches = microsecondsToInches(duration);
// //if objects are less than 12 inches away //the robot reverses and turns to the right //for 2 seconds //
if (inches < 12){
//brake drive motor and pause 1/10 second digitalWrite(9, HIGH); delay(100);
// //setting turn motor //
//turn off brake for turn motor digitalWrite(8, LOW);
//set turn motor direction digitalWrite(13, HIGH);
//activate turn motor analogWrite(11, 255);
// //setting drive motor //
//turn off brake of drive motor digitalWrite(9, LOW);
//set drive motor backwards direction digitalWrite(12, LOW);
//activate the drive motor analogWrite(3, 200); //backup for 2 seconds delay(2000);
// //stopping //
//brake both motors digitalWrite(8, HIGH); digitalWrite(9, HIGH);
// //when nothing is within 12" //the robot simply drives forwards //
else{
// //Setting drive motor //
//set drive motor forward direction digitalWrite(12, HIGH);
Arkadaslar up up .ne olur ne olmaz hangi pinlere ne gelecek onu da söyler misiniz .mantıksal olarak en doğrusunu yaptığımı biliyorum hepsi doğru ama çıldırmak üzereyim
motorları da l298p nin a ve b çıkışlarına bağlıyorum ama nafile.
