Firmware 30.0.019 per N82. --Changes/improvements-- * Alarm: Updates to Calender for Alarm related Issues * Audio: Enhancement to Radio Apps * Barcode reader: Decoded data view, Unsaved barcode with no links, options list is in wrong order * Bluetooth Enhancements * Browser Enhancements * Core Telephony: Security, USIM, PCP, TTY related fixes, E.g. * From PCP: Aino: WCDMA OTC USIM Freeze GSM Access and Security disabled * CommonTsy copyerror: From PCP: Aino: WCDMA OTC USIM Freeze GSM Access and Security disabled * From PCP: Cert Nonpass: TC 31.9.2.1 (51.0101) PCS1900 * TTY doesn’t work (QC defect ID 188) * Video Editors fix & Enhancements * Email fixes and enhancements * Music Player enhancement & Fixes, for e.g. * Orange XML GSM/WCDMA OTC Refreshing Music Library Looks like app has locked up * Phone hangs while playing the video “Batman Begins” * Java Core Runtime and Java Extension Fixes and Enhancements, e.g. * SFR GSM/WCDMA OTC Misc: Applications stored on the mass memory are very slow * When playing OMA1 protected files in a J2ME app using JSR135 throws an exception in S60 3.1 devices * Lifeblog Enhancement wrt DB file * Maps2.0 related Fixes and Enhancement need to maturize the same * NGage related Error Fixes and Enhancements * Camera Related Enhancements and fixes * Security Fixes * ASR enhancement * Share Online Related Fixes needed for Maturization of application * SIP enhancements and Fixes * SMS Related Fixes and Enhancements * Telephony adaptation Related Fixes and Enhancements * UPnP Enhancements * Video Center Enhancements * VoIP Related Error Fixes and Enhancements * Flash Lite3 Related Enhancements and Fixes * WLAN related Fixes and Enhancements * Sharaku Restore Factory Settings Misses Data for NGage in UDA --New features/functionalities-- * Full NGI (Ngage Application) * Settings Wizard Update * Maps 2.0 * Online Share 3.0 * Mosh & Ovi Bookmark * Startup Setting Update * One Way Refresh over PIM * Default Calender Year to be 2008 * ASR Improvements * Mobile Search 4.0 with Google Plugin * VMBX call divert Indicator Removal for Orange variant * Download Client Version Update to 3150 * Ngage Trial Games on UDA: Snakes Subsonic and Block Breaker * Snakes Only in MEA Region * Block Breaker Game in Indonesia & Philipines Region Artık bi arkadaş Çevirisini yapar ![]() |
Kayda değer hiç1şey yok ama yinede çeviririm TR'ye ![]() SS'li 10 adet yeni tema eklendi... http://www.reis-ieagles.com/temalar/ ![]() |
Reis güzel temalar var ama resimleri açmada sıkıntı oluyor, tam açmıyor nedense yarım kalıyor ![]() |
Yeni versiyonu yükledikten sonra multimedia tuşu bendede çalışmaz oldu soft format attım yine çalışmıyor teli kapatıp açtım fayda etmedi,ne yapmak lazım,bilgisi olan varmı acaba? |
Neyseki düzelttim hard format attım...![]() |
çok teşekkür ediyorum ilgilendiin için ![]() ![]() ![]() |
bende siyah n 82 ile aranıza katıldım. forumu ilk sayfadan bu güne okudum, aylardır takipteyim. önce bir kurcalayım, sonra takıldığım yerleri sorarım. buradaki bazı arkadaşların (isim vermeyim unuttuklarım üzülür) usanmadan herkeze cevap vermelerini taktir ediyorum. |
Nerden ve kaça aldın kardeş. Edit: Hayırlı olsun. |
Hayırlı olsun Emei kontrolu yaptın mı ithalat yoluyla filan diyor mu? |
Bende siparişi vermiştim hizlialdan 4-5 gün önce siyahını, fakat sipariş halen daha tedarik sürecinde olunca,msj attım ve bilgi istedim ne zaman elime geçeceği konusunda,msjı aynen copy paste yapıyorum Değerli Müşterimiz ÜRÜNLERLE ILGILI OLARAK IMEI NUMARALARINA HATA OLDUĞUNDAN DOLAYI FIRMA ÇIKIŞ YAPAMAMIŞTIR VE ÜRÜN 28.09.2008 TARİHİNDE STOKLARDA OLUCAKTIR. merhum sen ne zaman vermiştin siparişi? Ve telefonun olduğu bölüme 28.09.2008 tarihinde stoklarda olucak ibaresi koymuşlar,1 hafta beklemek zorunda kalıcam ![]() |
versiyon yükselttik şimdi unsigned uygulamalarla başbaşa kaldık iyimi![]() ![]() ![]() ![]() ![]() |
yok lea normal. ![]() kaydırma çubuğunu indir aşağıya bütün tarayıcılarda denedim normal ![]() ie7, ie8 beta2, ff3, ff2, safari, opera ve chrome |
maşşallah reis denemdik bişe bırakmamışsın |
hos ve cool bi telefonmus![]() ![]() |
siparişi 12.9.2008 de vermiştim. imei numarası kayıtlı , ithalat yoluyla gelmiş diyor. bu kötü bişey değildir umarım. |
[Düzenlendi] Menünüz hiç küçülmesin... (Menü İkonunu Kaldırma & Silme) Anlatımda denilen dosyaları nolur nolmaz yedekleyin. ![]() http://rapidshare.com/files/146852676/101F8847.txt 1-) Sistem dosyalarına erişimi sağlayın. Sistem ve gizli dosyaları göstertin. 2-) C:\private\10202be9\persists\ içindeki 101F8847.CRE dosyasını silin. 3-) Anlatımda verilen 101F8847.TXT dosyasını C:\private\10201be9\ dizinine kopyalayın ve cihazı yeniden başlatın. ![]() Tüm olay bu kadar. ![]() Düzeltme için crux2005'e teşekkürler. ![]() |
dur yapim hemen ![]() ![]() Reis imzan değişmiş sanırım büyük ekran ve çözünürlük seni windows mobile ye kaydırıyor. ![]() ![]() |
Kardeş N-gage'i indirdiysen uygulamalar klasörünün içine giriyor. Ordan taşı komutuyla klasörün içindeki yerini değiştirebiliyorsun. Ama klasöre taşıyı seçip ordanda kök klasörü seçersen menüye almış olursun. Yanlış anlamadıysam sorun bu . Bunun için güncellemeye format atmaya gerek yok eğer sorun buysa.
