Java inner class problem
8 yıl
combobox'a veri eklemeye çalışırken non-static variable jComboBox1 cannot be referenced from a static context hatası alıyorum
    private static String readUrl(String urlString) throws Exception {
BufferedReader reader = null;
try {
URL url = new URL(urlString);
reader = new BufferedReader(new InputStreamReader(url.openStream()));
StringBuffer buffer = new StringBuffer();
int read;
char[] chars = new char[1024];
while ((read = reader.read(chars)) != -1)
buffer.append(chars, 0, read);
return buffer.toString();
} finally {
if (reader != null)
reader.close();
public static class MySQLEntry {
public String id;
public static String ad;
public String latitude;
public String longitude;
public String speed;
public String hour;
public String day;
public String adres;
public String resimyol;
public String getId() { return id; }
public static String getName() { return ad; }
public String getlat() { return latitude; }
public String getlon() { return longitude; }
public String getspeed() { return speed; }
public String gethour() { return hour; }
public String getday() { return day; }
public String getadres() { return adres; }
public String getresim() { return resimyol; }
public static void main(String args[]) {
/* Set the Nimbus look and feel */
//<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
/* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
* For details seehttp://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
try {
for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
if ("Nimbus".equals(info.getName())) {
javax.swing.UIManager.setLookAndFeel(info.getClassName());
break;
} catch (ClassNotFoundException ex) {
java.util.logging.Logger.getLogger(KonumGoster.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
} catch (InstantiationException ex) {
} catch (IllegalAccessException ex) {
} catch (javax.swing.UnsupportedLookAndFeelException ex) {
//</editor-fold>
/* Create and display the form */
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new KonumGoster().setVisible(true);
String json = null;
try {
json = readUrl("http://url/"
+ "json.php");
} catch (Exception ex) {
Logger.getLogger(KonumGoster.class.getName()).log(Level.SEVERE, null, ex);
Gson gson = new Gson();
MySQLEntry[] array = gson.fromJson(json, MySQLEntry[].class);
for (MySQLEntry obj : array) {
//MySQLEntry x =new MySQLEntry(obj.getName());
jComboBox1.addItem(getName());
System.out.println("ID: " +obj.getId());
System.out.println("Ad: " +obj.getName());
System.out.println("Latitude: " +obj.getlat());
System.out.println("Longitude: " +obj.getlon());
System.out.println("Speed: " +obj.getspeed());
System.out.println("Saat: " +obj.gethour());
System.out.println("Tarih: " +obj.getday());
System.out.println("Açık Adres: " +obj.getadres());
System.out.println("Harita Üzerinde: " +obj.getresim());
