Help in Hardware Compatibility Issue
2 yıl (1 mesaj)
Hello everyone,
I hope you're all having a great day. I'm encountering a bit of a dilemma with my hardware setup and I was hoping to get some advice from the knowledgeable community here.
Recently, I upgraded my graphics card to a newer model, but I've been experiencing some compatibility issues with my motherboard. Whenever I try to run graphics-intensive applications or games, my system freezes or crashes. I also check this : https://forum.donanimhaber.com/yardim-edin-warning-the-boot-devices-have-been-changedalteryx But I have not found any solution
I've tried updating my drivers and BIOS, but the problem persists. I've also checked for any physical damage or loose connections, but everything seems fine.
Has anyone else faced a similar problem with their hardware setup? If so, how did you troubleshoot it? Any insights or suggestions would be greatly appreciated.
Thanks a lot for your time and assistance!
Best regards,
2 yıl (2247 mesaj)
You should do clean setup your hard dirve or ssd.Probably your boot devices mbr format you can convert to gpt format on windows setup screen.After that you can clean setup.
https://www.youtube.com/watch?v=f81qKAJUdKc
Also you dont forget uefi setup.
