489
ACER 23.6' GN245HQBMID 3D LED MONİTÖR Kullanıcı İncelemesi ve Kullananlar
13 yıl
ACER 23.6" GN245HQBMID 3D LED MONİTÖR Kullanıcı İncelemesi ve Kullananlar
Monitörü Vatandan 23/03/2012 tarihi itibariyle %25 indirim ile 802-TL'ye 10 taksitle aldım.
Alma amacım tamamen oyun amaçlıydı.
http://www.acer.com.tr/ac/tr/TR/content/model/ET.UG5HE.015
http://www.digitalversus.com/lcd-monitor/acer-gn245hq-p10694/test.html
http://www.vatanbilgisayar.com/Monit%C3%B6r/acer-gn245hqbmid-236-gn245hqbmid-genis-ekran-3d-led-monitor-+-nvidia-gozluk/productdetails.aspx?I_ID=56057
_______________________________________________________
digitalversus'dan alıntı:
Responsiveness: excellent—but not quite perfect < Resime gitmek için tıklayın >
Our tests clearly demonstrated that the fact that you're sending new frames to the monitor at a rate of 120 Hz instead of 60 Hz doesn't necessarily half the ghosting time. The GN245HQ still has a very low ghosting time, ensuring very smooth movements without any blur. That also serves to iron out the irritating crosstalk effects when viewing in 3D, where the signal for each eye gets confused with the other.
Measured responsiveness
Light background Black background Average
This graph shows the 'ghosting time' of the monitor.
The lower these figures, the more responsive the monitor is.
In fact, the GN245HQ is the monitor with one of the lowest ghosting times we've ever tested. It's as good as the LG 15EL9500, making it an excellent choice for avid gamers in two or three dimensions. The only hitch that might leave the most demanding users to hesitate is some light—and we really do mean 'light'—reverse ghosting.
There's nothing to report about the input lag: it does exist, but it's so low that you won't be able to detect it with the naked eye. There's no chance it will have a negative impact on
_____________
PLUSES (ARTILARI)
- Very low ghosting time - Çok düşük gölgelenme zamanı
- Above average contrast - Ortalamanın üstü kontrast
- Compatible with more 3D sources - Daha fazla 3D kaynakları ile uyumlu
- Built-in 3D transmitter - Dahili 3D verici
MINUSES (EKSİLERİ)
- Very, very light reverse ghosting - Çok, çok hafif ters gölgelenme
- Not very customisable - Çok özelleştirilebilir değil
- Colour reproduction could be more accurate - Renk sunumu daha doğru olabilir
< Resime gitmek için tıklayın >The GN245HQ is a great 120 Hz monitor, whose HDMI 1.4 input leaves it open to 3D content from a Blu-ray 3D player, a PlayStation 3 or graphics cards from either ATI or Nvidia. That makes it all the more disappointing that Acer hasn't improved the usability or the accuracy of the colour reproduction on its latest 24'' display.
Teknik Bilgiler
Panel Tipi TN
Ekran Sayısı 1
Ekran Boyutu 60 cm (23,6")
Ekran Modu Full HD
En Boy Oranı 16:9
Yatay Görüş Açısı 176°
Dikey Görüş Açısı 176°
Ayarlanabilir Ekran Açısı Var
Montaj Türü Duvara Monte Edilebilir
Arka Aydınlatma Teknolojisi LED
HDCP Destekli Var
Video
Maksimum Çözünürlük 1920 x 1080
Standart Yenileme Hızı 120 Hz
Desteklenen Renk 16,7 milyon renk
Kontrast Oranı 100,000,000:1
Parlaklık 300 cd/m²
Ses
Hoparlör Sayısı 2
Hoparlörler Var
Ara Yüzler/Bağlantı Noktaları
DVI Var
HDMI Var
VGA Var
Yerleşik Aygıtlar
Yerleşik Aygıtlar Hoparlör
Güç Açıklaması
Çalışırken Güç Tüketimi 38,20 W
Beklemede Güç Tüketimi 1,85 W
Kapalı Mod Güç Tüketimi 850 mW
Fiziksel Özellikler
VES Montaj Uyumlu Var
VESA Montaj Standart 100 x 100
Renk Siyah
Yükseklik 418,0 mm
Genişlik 575,0 mm
Derinlik 194,0 mm
Ağırlık (Yaklaşık) 5,00 kg
Çeşitli
Yeşil Uyumlu Var
Yeşil Uyumluluk Sertifikası/Yetki MPR II
RoHS
Energy Star
Garanti
Garanti Standararanti
Büyük bir kutusu var
Kutu içeriğinde HDMI ve DVI kablosuna kadar lazım olacak tüm kablolar mevcut.
Hatta dahili hoparlörü olduğu için ses kablosu da var ama monitörün kendi hoparlöründen pek memnun kalmadım.
Ses yeterince kaliteli değil.
İyi bir müzik kulağınız var ise sizi kesinlikle tatmin etmez ama günlük uygulamalar için yeterli diyebilirim.
Monitörün görünüşü güzel diyebilirim üstelik yeterince büyük
OSD tuşları resimde gördüğünüz gibi alt tarafta gizlenmiş
OSD menüsü pek kullanışlı değil:
LED olduğu halde ince sayılmaz
Arkadan görünüş ve bağlantılar
Daha önce kullandığım samsun LCD monitörde kontrast iyi değildi ve ışık sızmaları rahatsız ediciydi ama bu monitörde kontrast beni tatmin etti ışık sızması da yok
Tamamen yok diyemeyiz ama kontrastı düşürmeyecek kadar az diyelim.
Ekran tamamen siyah olduğunda ekranın alt tarafında biraz sızma hissediliyor ama kontrastı bozmayacak kadar az sayılır.
Nvidia 3D Vision Gözlük
Kutu içeriğinde gözlük, USB şarj kablosu, farklı burun tipleri için 3 adet burun tamponu, gözlük kılıfı ve silme bezi
Çok önemli bir avantaj: IR alıcı ve verici monitörün içine monte edilmiş olduğundan harici IR vericisine ihtiyaç yok ve bu çok iyi
Koyuncu garantili
Nvidia 3D Vision için bağlantı olarak DVI seçmelisiniz.
HDMI ile 3D TvPlay olarak çalışıyor ki bu da 1080p 60Hz olmuyor.
Daha önce LG nin pasif gözlüklü monitörünü denemiş birisi olarak gerçek 1920x1080p 60Hz için Nvidia 3D Vision'un şart olduğunu anladım.
Nvidia 3D Vision 2'nin ve lightbooster'ın esprisini de anlamış bulunmaktayım; Çünkü 3d modda hafif kararma oluyor ama ben bunu, oyunu karanlık odada oynadığım için sorun etmiyorum...
Karanlık odada zaten çok parlak ayarlarda oynamak göz sağlığı için tehlikelidir.
Şimdilik ilk izlenimlerim olumlu yönde,
Üstelik piyasada gerçek 3d deneyimi yaşayabileceğimiz ucuz ama en iyi monitör bu.
Tabiki de ASUS'un Nvidia 3D Vision 2 Lightbooster monitörleri belki daha iyidir ama bugünkü %25 indirimle bile 23" olanları 1200-TL'ye geliyor ki param olsa asus alırdım herhalde...
Gözlüğün eksileri:
Uzun süre kullanımdan sonra nvidia 3d vision gözlüğün nekadar ucuz malzemeden yapıldığını anlayacaksınız.
3d görüntü açısından tatmin edici olsa da
malzeme kalitesi,
kulakları rahatsız eden sapları,
zamanla şekli bozulup sürekli yerinden çıkan burun tamponları,
silme beziyle bile mikro çizikler oluşan ve yansıma önleyici polarize yüzeyden yapılmamış en ufak şeyde tozlanan ve kirlenen camlarıyla tam bir rezalet...
SON SÖZ OLARAK ŞUNU SÖYLEMELİYİM Kİ
MONİTÖRDEN EN ÇOK MEMNUN OLDUĞUM ÖZELLİK
GÖRÜNTÜNÜN AKICILIĞI
BU AKICILIK 2MS TEPKİME SÜRESİ VE 120HZ OLMASINDAN KAYNAKLANIYOR
AKICILIK ÖZELLİKLE 2D PERFORMANSINDAN ZİYADE 3D PERFORMANSINDA HİSSEDİLİYOR
ACER BENİ BU KONUDA TATMİN ETTİ
HERHALDE BİR DAHA MONİTÖR ALACAK OLSAM ACER ARAŞTIRIRIM
Monitörün kendi yazılımı Acer eDisplay Management
http://forum.donanimhaber.com/m_55613195/mpage_1/f_/key_/tm.htm#55613195
http://forum.donanimhaber.com/m_49895815/mpage_1/key_/tm.htm
http://www.pclabs.com.tr/2009/11/17/nvidianin-stereoskopik-3-boyut-yorumu-geforce-3d-vision/
http://www.nvidia.com/object/3d-vision-main.html
review
Orijinalden alıntı: shadow99tr
Bu arada benim monitörü duvara monte ettim arkasına dahttp://www.hepsiburada.com/Liste/brateck-lcd-151am-10-32-4-hareketli-lcd-duvar-aski-aparati/productDetails.aspx?productId=evbratklcd151am&categoryId=17539#Gorseller bu askıdan aldım..Dünde logitech x530u yanlarına monte ettim..Bir arkadaşımdahttp://urun.gittigidiyor.com/ev-dekorasyon-bahce/ikea-norbo-duvara-katlanabilir-masa-yer-tutmaz-29093782#product-information bu katlanır masadan yaptı.Pazartesi getirip takacak o zamana kadar idarelik bir masa koydum.Keyif alıyorum pc başında durmaktan ve rahat rahat bf3 oynamaktan :)
< Bu mesaj bu kişi tarafından değiştirildi OguzhanKeskinbalta -- 7 Ekim 2012; 22:07:08 >
13 yıl
Koydugun resim GD ye ait
Biizmkini turuncu ayaklari yok...
Arkadas bir baska konuda yazmis photoshop icin iyi degil diye. Orasi oyle olabilir EMIN degilim, fakat oyun icin ve film icin alicaksan mutlaka al. 800 lira cok uygun bir fiyat 3D vision destekli bir monitor icin.
Ben baska bir 23 inch veya 24 inch ekrana gecmem fakat 27 inch ekrana gecmeyi dusunebilirim yil sonu ancak o zaman degistiririm.
Su incelemeyi oku
http://3dvision-blog.com/5601-24-inch-acer-gn245hq-120hz-3d-capable-lcd-gaming-monitor-review/
Ayni burdada denmis, oyun icin alicaksaniz alin, ama profesyonel calismalar yapicaksaniz baska monitor secebilirsiniz diye.
Guzel bi inceleme.
13 yıl
teşekkürler bugün monitöre bakacağım inşallah
ama bu photoshop meselesi ancak ips panel ile çözümlenebilir ki zaten tn paneller bu konuda profesyonel değiller
13 yıl
Orijinalden alıntı: svstrgmr
Olabilir o konuda bir fikrim yok. Photoshop ile isim olmadi su gune kadar acikcasi
Incele monitoru. Oyun oynayacaksan genelde ve film ise amacin seveceksindir diye dusunuyorum.
bu fiyatada kacmaz gercekten. Ben 1.300 e almistim hic biyerde yoktu stoklarda kalmamisti. Istanbul bilisimden aldim.
1 hafta sonra tekrar Vatan stoklarina girdi 1000. tl ye. Ayni haftasonuda indirim oldu 25% gelde kafayi yeme. Neyse hatirlamamaya calisiyorum
13 yıl
Ha bu arada unutmadan internetten yukledigim bir renk profilini kullaniyorum bu ekran icin.
Harika bir profildir.
Ilgilenen olursa linki verebilirim.
Ilk monitoru actiginda hic birseye dokunmadan bu profili koyarsan mesela cok daha guzel renkler goruceksin.
Nvidia Control Panelden de Digital Vibranca acarsan harika olur. 85% gibi
< Bu mesaj bu kişi tarafından değiştirildi iARDAs -- 23 Mart 2012; 14:12:56 >
13 yıl
şu anda monitörü söğütözü vatandan 800-tl'ye 10 taksite aldım ve masama kurdum
HDMI ile renkler soluk sarımtrak duruyor dediğin renk profilini kullanmak isterim
çünkü DVI renkleri normal ama HDMI renkleri yanlış gibi duruyor
13 yıl
Hayırlı olsun..Nasıl hocam ufak bir inceleme yapabilirmisin?Bende kafaya koydum,alacagım bunu.
13 yıl
Teşekkürler
Aceleyle şimdilik resim ve birkaç yorum ekledim.
Merak ettiğin birşey olursa sorabilirsin.
13 yıl
Teşekkürler
Hocam sagolasin inceleyim yazdıklarınızı, üstüne kılıfta alsaydınız yenge görmesin:)
13 yıl
peki hocam dvi çıkışı sesi aktarıyor mu?sesi almak için illa hdmi bağlamak şart mı?birde 3dde olan karanlık görüntüyü 3dye geçmeden monitörü en parlak seviyeye getirine lightboostu aratmaz sanırım..bf3 varmi sizde deneyebilme imkanınız varmi akıcılık falan nasıl 120hzde kırılmalar falan yaşanıyor mu hala...
< Bu mesaj bu kişi tarafından değiştirildi oldboy83tr -- 23 Mart 2012; 18:42:40 >
13 yıl
Birde film izlerken 3d derinliğini arttırmak için bir kaç tuş varmış,sağ-sol gibi bir kaç ayar okumuştum daha iyi 3d veriyormuş galiba...iARDAs hocam biliyordur herhalde..Başka ne gibi ayarlar yapmak lazım acaba?3d vision klübü konusunda görmüştüm bir ara ayarlar falan yapıyorlardı..Ama konuyu bulamadım şimdi..
Işık sızmasının vs olmaması güzel..Umarım ölü pixel ve ghosting sorunuda olmazda güzel güzel kullanırsınız..
Burada ghosting test varmış işinize yarar umarım..
http://www.prad.de/en/monitore/testsoftware/ghosting-test.html
< Bu mesaj bu kişi tarafından değiştirildi oldboy83tr -- 23 Mart 2012; 18:41:41 >
13 yıl
Teşekkürler
DVI çıkışı ses aktarmıyor ama ses kablosunu takarak monitörden ses alabiliyorsun
ve normalde HDMI takınca ses almak gerekiyor ama ben nedense alamadım
Zaten monitörün hoparlörü kalitesiz, ben kulaklık kullanıyorum.
Şimdilik skyrim ile denedim ve beni tatmin etti. Bf3 birazdan denerim...
Derinliği maximumda kullanıyorum ve böylesi daha çok hoşuma gidiyor ama bazen gözüm şaşı oluyor...
Aslında memnun kalmasam acımasızca eleştirirdim ama tepkime süresi iyi olduğu için ghosting yaşamadım ki bu konuda çok hassasım.
Kısayol tuşları bunlar
dediğin konu bu muydu?
http://forum.donanimhaber.com/m_49895815/mpage_6/f_/key_//tm.htm#58979071
< Bu mesaj bu kişi tarafından değiştirildi OguzhanKeskinbalta -- 23 Mart 2012; 19:17:52 >
13 yıl
Dostum selam
Renk profilini sana birazdan yollarim.
Direk ben o profili kullaniyorum ama HDMI ile hic baglanmadim. Sirf DVI
o renk profilinide nasil aktif hale getirecegini soylerim...
bu arada SKYRIM de gokyuzu 3D degildir. Bunun icin bir mod var onuda ilistiririm sana.
Battlefield 3 De haritada disarida isen ve ileride ufuk cizgisi cok uzak ise 40 fps ye kilitleniyor oyun 3Dde. bu oyun motorunun bir sorunu, bir sonraki gelecek driver ile bu sorun hallolucak isallah....
Sormak isteyecegin konu var ise LUTFEN sor..
Renk profilinide en gec 1 saat icinde sana aticam.
Nvidia 3Dvision 1 monitorlerde Ghosting olarak en iyi 2 monitorden birici Acer Gn245, digeride Planar diye bir marka, malesef turkiyede yok.
Fakat illa ghosting azda olsa oluyor. teknoloji su an 0 ghosting i yakalayamadi.
13 yıl
@iARDAs
her türlü yardımına ihtiyacım var ve ben nvidia 3d vision konusunda acemiyim.
Peki bu nvidia 3D Vision Ready ne demek?
Yani tam anlamıyla nvidia 3d vision değil mi demek
Şimdi masaüstünde de 120Hz kullanıyorum ve mouse işaretçisi yağ gibi akıyor
13 yıl
Dostum basliyorum
Oncelikle bu ekrani HDMI kullanma.. Ha HDMI baglantili birseye bagliyacaksindir o ayri, ama DVI ile devam et bilgisayarinda.
1-) 3D vision ready demek. 0 hata veya 0 hataya yakin, tamamen 3D icin dizayn edilmis oyun demek. Oyun yapimcilari bu oyunu yaparken kisacasi 3Dyi kafalarina koyup oyle dizayn etmislerdir.
Ben mesela alabildigim kadar 3Dvision Ready oyun aliyorum. Inan bana iclerinde su an tek problemli olani Battlefield 3, oda duzelecektir yakinda...
2-) Arada bir 3D oyna, sonra mutlaka 120 hz 2D olarak oyun oyna. 120 FPS alabildigin oyunlarin nasil yag gibi akip gittigini goreceksin. Ben bazen oyunlari 2d 120 hz oynuyorum, bazen 3d 60hz. O an ki moduma gore, ve ikiside mukemmel zevklerdir.
3-) Profile gelince.
*http://img1.focus-numerique.com/focus/profils-LCD/Acer%20GN245HQ.icc linkinden bizim monitor icin digitalversus sitesinin profil kalibrasyon dosyasini indir. Adamlar cihazlarla yapiyorlar bu kalibrasyonu.
* Indirdikten sonra C:\Windows\System32\Spool\Drivers\Color\ ne git ve oradaki AcerGn245HQ dosyasini yeni yukledigin dosya ile degistir. (istersen digerini baska bir yere backup olarak koy
* Masaustunde saga tikla
Ekran cozunurlugunu sec
Gelismis Ayarlara bas
RENK yonetimini sec ustte
Renk yonetimine bir daha bas
Bu aygit icin benim ayarlarimi kullan kutusunu isaretle
Acer Gn245 listede cikmasi lazim. ( monitorun driverlarini bastan kurduysan tabi)
Acer Gn245 in ustune gel ve EKLE de.
GOZAT yap
Oradan C:\Windows\System32\Spool\Drivers\Color\ deki ACERGN245 HQ icc profilini sec
zaten o an renklerde filan hemen bir degisikligi hissetmen lazim.
Bu islem bittikten sonra Acer Gn245 in ustune gel ve VARSAYILAN PROFIL OLARAK SAY a tikla
Ondan sonra hemen ayni pencerede GELISMIS e git
Aygit Profili var en ustte ve Acer Gn245HQ.icc profilini sec... Ok de ve bitsin hersey
Ha ben ekstra olarak Digital Vibrance i 85% yapiyorum harika oluyor
Artik gerisi kendi zevkin.
bu ayarlar adamlarin testler sonucu renklere en yakin geldigi noktalar. Tabi bunu fabrika ayarli bir monitor ustunde yapmak daha verimli olur
Baska sorun varsa sor lutfen. 3D hakkinda cok sey biliyorum ve oyun onerisi her zaman yapabilirim.
13 yıl
Teşekkürler
yok hocam 2-3 sayfa olmuş bir konuydu bulursam eklerim..
13 yıl
Dostlar sagolun sayenizde bende alınca güzel bir kaynak olacak benim icin :)
13 yıl
Hayirlisi :)
svstrgmr den ses seda yok
13 yıl
Orijinalden alıntı: iARDAs
Hayirlisi :)
2 ihtimal var ...
ya monitörün keyfini sürüyor ya da yenge monitörü kırdı:))
13 yıl
Hayirlisi :)
2 ihtimal var ...
Umarim hosuna gitmistir ve renkleri istedigi gibi ayarlamistir.
Ilk acildiginda monitor renkler ahim sahim degil. Guzel aslinda ama daha iyi olabilir yani.
