1684
Cevap: 2016 PHİLİPS LCD & OLED ANDROİD TV (83. sayfa)
8 yıl
Su sekilde bilgiler. Ne diyorsunuz?
General
Unique ID : 233893816574034649913426270802264131686 (0xAFF64F7DE41B7A83A69AFEA034570866)
Format : Matroska
Format version : Version 4 / Version 2
File size : 20.7 GiB
Duration : 1h 59mn
Overall bit rate mode : Variable
Overall bit rate : 24.9 Mbps
Encoded date : UTC 2016-04-02 02:56:27
Writing application : mkvmerge v9.0.0 ('Power to progress') 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
DURATION : 01:52:52.098000000
NUMBER_OF_FRAMES : 2671
NUMBER_OF_BYTES : 8519676
_STATISTICS_WRITING_APP : mkvmerge v9.0.0 ('Power to progress') 64bit
_STATISTICS_WRITING_DATE_UTC : 2016-04-02 02:56:27
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 1h 59mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 59mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Delay relative to video : 42ms
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Language : Spanish
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Language : French
Default : No
Forced : No
Bu mesajda bahsedilenler: @Cnrps
8 yıl
Bir sey daha sormak istiyorum. Android yukselince video oynatma performansinda iyilesme oldu mu?
Ben Plex kullandigim icin cihazin oynatma kapasitesi onemli. Videolari dogrudan oynatabilmek istiyorum. Plexde stream de var ama o devreye girince cozunurluk dusuyor ya da takiliyor yuksek cozunurluklu dosyalarda.
65pus6521 almayi dusunuyorum. GGde 5900 civarinda satista. Bugun alirsam 100 lira da aninda indirim olacak. Alinir mi acaba, kafam karisik...
< Bu mesaj bu kişi tarafından değiştirildi kultablasi -- 2 Nisan 2017; 8:52:27 >
Bu mesajda bahsedilenler: @rockNpel
8 yıl
Hocam bana vc1 görüntü codec inden gibi geldi. Esasında bitrate FPS değerleri yüksek değil ancak tv lerin vc1 desteği sınırlı sanıyorum. H264 / h265 ile encode edilmiş filmleri tercih etmek daha uygun bir seçim olacaktır bu format daha bir fazla destek görüyor hemde TV ler tarafından daha kolay oynatiliyor.
Ekstra not:Hocam 65pus6521 in vatanda 5300 e satıldığını hatta ekstra indirim talebi ile sıfır kutuyu 4900 e mal edenler var piyasayı iyi takip edin derim. Sanıyorum TV Arçelik bayi lerinde de satılıyor gidin pazarlık yapin yollayın.
< Bu mesaj bu kişi tarafından değiştirildi Cnrps -- 2 Nisan 2017; 9:16:17 >
8 yıl
Bilgilendirme icin tesekkurler. Sorun DTS olabilir diye dusunmustum ama oyle olsa videoyu en azindan sessiz bicimde oynatirdi herhalde?
Vatanda bu TV sadece istanbul ve mardinde var maalesef. Ben Ankaradayim. Arcelik konusunu bilmiyordum ama ona da webden bakinca stokta yok gozukuyor. Fiyati da bayagi yuksek!
Peki sizce 7000 liraya + telefon hediyeli Samsung 60ks8000 mi yoksa bu mu? Siz hangisini tercih ederdiniz?
8 yıl
55pus6581 kullanıcısıyım. kullanan arkadaşlara bir sorum olacak. dlna sunucusu üzerinden izlediğiniz filmlerde altyazı sıkıntısı çekiyor musunuz?
ben bir türlü bu sorunu çözemedim. filmi usbden izlediğimde sorun yok dlna dan izlediğimde altyazı gözükmüyor.
8 yıl
Orijinalden alıntı: doruuuk
kodi yükleyin. kodi içerisinden dlna üzerinden erişim sağlayıp bsplayer altyazı vs altyazı eklentileriyle filmlerinizi altyazılı izleyebilirsiniz.
8 yıl
Orijinalden alıntı: ozandemir-
kodi de yüklü hocam onda da dts seslerde sıkıntı yaşıyorum. ilk 5 dk sorun yok sonrasında ses gidiyor. izlediğim filmler x264 1080p
8 yıl
Yazılım çökmesi nedeniyle servis Pus6501 tvmi aldı gitti.Ok tuşlarıyla recovery edilebilme şansı varken neden götürüyorlar anlamış değilim.
8 yıl
bende dizi izliyorum genelde pcdeki klasörüme erişerek kodi üzerinden. seste sıkıntı yapmaması lazım. eklentileri var belki orda ses codecleri bulunabilir oraya bir bakın derim.
W
8 yıl
Orijinalden alıntı: h_orion
Bir sene önce Philips 42pfk6309 tv satın aldım.Pişşşşmann oldum..Kanal geçişleri rezalet ötesinin de ötesi.Bir kanaldan ötekine geçerken ömrümden 5 sn ve daha fazlası gidiyor.
Bi de şöyle bi sorun var.Yardım menüsünde bahsedip açıklıyor ama menü ve ayarlar kisminda
"Clear LCD" ve "Mükemmel Doğal Hareket" diye bi seçenek yok.
Bu modelde mi yok yoksa benmi bulamadim acaba?
Bir sene önce bende büyük biradere ısrarla üst seviye samy alalım dememe rağmen illaki philipste ısrar etti gittik vatandan gözümüze kestirdiğimiz 40 inç 1600 tl lik modelini aldık...Görüntü kalitesi sinema modlarında eh idare eder..Fakat dediğin gibi kanal geçişleri olsun menüde gezinme ve smart üzerinde gezinme felaket ötesi :( bir kanaldan diğerine geçmek için 4-5 sn bekletiyor kanal menüsü açılsammı açılmasammı diye kasım kasım kasılıyor üst üste kumandadan müdahale edince alet kilitleniyor kapanıyor tekrar açılıyor..servisi aradığımda görüntüyü dahada güzel hale getirmek için işlem yapıyormuş buda gecikme yaratıyormuş telefondaki adama neredeyse küfür edecektim..
10 sene önce aldığım 46c650 samy televizyonumun değil yakınından uzağından bile geçemez yemişim smartını 10 yıllık tv nin ne görüntü kalitesine nede işlemci hızına yaklaşamıyor bile..benim tv de 3d olmadığı halde cisimler, insanlar sanki ekrandan fırlayıp çıkacakmış gibi 3d hissi veriyor hd görüntüler cam gibi temiz ve doğal..
Philips tv de tek beğendiğim olayı 3d filmlerde performansı fena değil kaldıki bir ara izleme fırsatı bulduğum lg tv nin 3d sine yaklaşamadı...Elektronik teknisyeni ve zamanında vestel üretim tesisinde çalışmış biri olarak açık konuşayım Albani usta samy ve sony ye bence haksızlık yapıyor :)))
W
8 yıl
Ve her zaman şunu söylerim tv alacak olan yakınlarıma ; ucuzuna kaçmayın üzerine biraz daha mümkün mertebe ekleyerek minimum orta veya orta üst segment bir tv alın.marka veya model olayına girmek istemiyorum lakin 2000-2500 tl den aşağı olan tv ler giriş seviyesi olup fazla bir şey beklememeniz gerekir.Maalesef en yakınım olan biradere bunları anlatmama rağmen gerek yok o kadar paralar vermeye dedi ve şu an bin pişman :)))
X
8 yıl
edit
< Bu mesaj bu kişi tarafından değiştirildi XibalbaTM -- 12 Nisan 2017; 3:22:37 >
8 yıl
Aileye 43'' Full Hd modelini aldık; 4131 serisi. Sadece tv izleme amaçlı alındı. Tüm gereksiz resim iyileştiriciler, görüntü kirliliği gidericiler vs ne varsa kapattım. Görüntü modunu sıcak yaptım. Video kontrastı ve parlaklığı da makul seviyeye çektim. Plazma kadar olmasa da doğala yakın bir görüntü sunuyor. Standart mod ve enerji tüketimi açık olarak kullanıyoruz.
Kanal geçişleri iyi denebilecek hızda. Sadece köşelerde karartı var ancak çok yakından ve dikkatli bakınca farkedeiliyor. Tv'nin en kötü yanı hoparlörleri. Bass'ı artırıp tizi kıstım. Bildiğin tenekeydi. Şimdiyse eh işte.
4k ve smart olmadığı için son derece mutluyum. A+ olması da cabası.
http://www.philips.com.tr/c-p/43PFS4131_12/4000-series-digital-crystal-clear-oezelligine-sahip-full-hd-ultra-ince-led-tv
8 yıl
Arkadaşlar ben aldım siz almayın, ben yandım siz yanmayın bizde philips 42pfk6309/12 modelini aldık cuma günü cumartesi sabah 10:30da kurdular iyi dedik bekletmediler hemen geldiler neyse hızlı hızlı kurdular tabi bişey soramıyosun adamların suratları bi karış gittiler yarım saat geçti geçmedi oda ne ekran yeşillenmeye başladı görüntü bozuldu renkler bi acayip oldu hemen kuranları geri aradım abi biz orayı geçtik geri dönemeyiz artık demezmi 0850 li bi numarası var orayı aradık size bağlı yetkili servisi arayın dedi yetkili servisi aradım anca pazartesi gelebiliriz dediler iyi dedik pazartesi aramışlar duymamışım 5 dakka geçmeden geri döndüm biz geçtik geri dönemeyiz yarın demezlermi servisi arıyorum onlar geçtiyse dönmezler yarın gelirler anca diyolar diyorum daha beni arayalı 5 dakka olmuyo benim yapabilceğim bişey yok diyo kapattım yüzüne telefonu neyse ertesi sabah gelmişler yine bir karış suratla tv kutusunun içindekileri atmıştık o köpükleri falan kutu duruyodu onuda çocuklar oynuyodu yok biz size kutuyu 6 ay saklayın demedikmi falan demişler halbuki öle bişey demediler sadece faturayı 1 sene saklayın dediler servise götürürüz sıra ne zaman gelirse yaparız demişler azarlar bir tavırla adamlar resmen hem suçlu hem güçlü bu arada tv den bahsedeyim birazda dahili uydu alıcısı berbat ötesi hele o kanal listesine girmek yokmu ölüm ölüm yani kanal değiştirmek istemezsin boşver şimdi kim uğraşcak onla dersin smartı fena değildi eh diyelim menüsü daha güzel olabilirdi görüntü kalitesi gerçekten güzeldi ama hele bide o ambilightlar muhteşem oluyodu philips alcaksanız gerçekten çok iyi bi sabrınızın olması gerekiyo öle böle değil yani yada iyi bitane harici uydu alıcısı almalısınız ha unutmadan ben telefonun ekranını bi türlü tv ye yansıtamadım baya bi uğraştım tam bağlancağı zaman başarasız diyo servisten gelince biraz daha uğraşcam bakalım
8 yıl
Arkadaşlar merhaba. Bende 49pus6581 var. Şöyle bir sorunum var güncellemeleri yüklemiyor TV . Fabrika sürümünden sonraki ilk güncelleştirmesini yükledim fakat sonraki güncelleştirmeleri bir türlü yükleniyor, Philips logosunda kalıyor
Ne yapmam lazım?
8 yıl
Selam arkadaşlar,
2017 tv modellerinden 2 si stoğa girdi.
2 sinden birini tercih edeceğiz aralarında 1. 000 tl gibi bir fark var.
Sizce bu farkı hakedecek kadar önemli özellikler var mı üst model de?
Ya da 6 serisini mi bekleyelim? Bu iki model 7 serisine ait.
http://www.epey.com/televizyon/karsilastir/75438-78097/philips-55pus7502_philips-55pus7002/
Teşekkürler.
< Bu mesaj bu kişi tarafından değiştirildi yelkowan -- 8 Mayıs 2017; 8:1:49 >
8 yıl
Orijinalden alıntı: yelkowan
Selam arkadaşlar,
Teşekkürler.
Hocam daha modeller yeni piyasaya çıkıyor bence erken biraz daha bekleyin karşılaştırmaları, özelliklerini iyi inceleyin.
www.displayspecifications.com a girdim sadece 7502 var, 7002 nin özellikleri orada listelenmemiş.
7502 de edge led yazıyor mesela paneli 10 bit ? Edge led olması negatif ama dediğim gibi erken, gidin teşhirde de görün inceleyin.
8 yıl
2017 PHILIPS TV'LERİ ana konunun zamanı gelmiş artık.
İşin uzmanı tarafından açılsa da oradan takip edip yeni paylaşımda bulunsak.
8 yıl
49 pus 7502 5000 civari pahali degilmi ?
8 yıl
normalde çok memnun olduğum kodiyle birlikte canına can katan pus6501 in bazen kafası karışıyor, smartlığından s kalmıyor ne internete erişim sağlıyor ne telefonu aktarıyor. bayadır olmuyordu bugün yine oldu. sebebi ne olabilir?
