3
Satılık klipsch RB-51 II Bookshelf ve RW-12d Subwoofer
Şehir : #İstanbul
14 yıl
Satıldı: Forum dışında
Kolonlar 1 hafta önce alınmış olup prof sisteme geçileceği için satılıktır.Garantili ve faturalılardır.
RW-12d Subwoofer
12-inch front-firing Cerametallic™ woofer
340-watt RMS amplifier
Digital user-interface
IR sensor
Capturing all the sonic excitement of low-frequency effects, the Reference Series RW-12d Digitally Controlled Subwoofer (DCS™) delivers rock-solid performances. With its class-leading technology and superior design, this hard-hitter perfectly rounds out a home theater or two-channel stereo music system.
The RW-12d shakes things up by employing a 12-inch front-firing Cerametallic™ woofer and a 340-watt RMS amplifier. Exclusive Corner Port™ Technology allows the subwoofer's port tube to be as long as possible without bending, minimizing turbulence that can cause port noise and distortion. It also allows the enclosure to be tuned to a lower frequency than would otherwise be possible to create deeper bass from a smaller cabinet. Another important element is a corner-shaped flange at the port's internal opening, which amplifies the benefits of a longer port.
For quick and easy adjustment of all functions, the RW-12d features the DCS digital user-interface that includes three equalization modes (flat, depth and punch) and three user-adjustable presets (music, movie and night) to create specific listening preferences.
Available in a black woodgrain vinyl finish, this extraordinary subwoofer also comes with an IR sensor for operation with select learning remotes or control systems.
http://www.klipsch.com/na-en/products/rw-12d-overview/
RB-51 II Bookshelf Speaker (Renk woodgrain vinyl )
Smart balance of performance, size and value
Fills medium-sized rooms with dynamic sound reproduction
Equally impressive with music and movies
Highly efficient design produces more output using less energy
Accurate, non-fatiguing sound provides hours of listening pleasure
Plays louder with less distortion than the competition
Enhanced 1" titanium horn-loaded tweeter, 5.25" high-output woofer
Dimensions: 11.4" H x 6.5" W x 10.75" D
Keyhole bracket for easy wall mounting
Dual threaded inserts for use with third-party stands
Beautiful wood-grain vinyl cabinet
The RB-51 II speaker offers up no-compromise music and movie performances in a smaller, more affordable bookshelf design. In fact, with its dynamic quality, superior sound and visual appeal, you’ll find this speaker simply irresistible.
The RB-51 II is complete with our proprietary Tractrix® Horn technology which produces a unique combination of precision, clarity and effortless power. Finished in a beautiful black ash woodgrain vinyl veneer, the RB-51 II is guaranteed to complement any décor.
New and Improved
Now in its fifth generation, Reference II speakers boast enhanced features, including re-engineered drivers and a new crossover system, to capture your attention and excite your emotions. In addition to the improved sound quality, the look of “big sound” has been redefined throughout the line with sophisticated cabinetry, refreshed logos and rounded feet.
Four Laws of the Klipsch Universe
Beginning in 1946, company founder, Paul W. Klipsch believed four principles to be the foundation for great sound. Together, these four design principles—high efficiency with low distortion, controlled directivity, flat frequency response, and wide dynamic range—have and always will be the foundation for our stunningly powerful and precise sound.
Tips and Tricks
For helpful tips and additional speaker information visit our online FAQs.
Features
Every Reference speaker utilizes our Tractrix® Horn technology for lifelike sound, more output using less energy, improved reliability, reduced distortion and a large soundstage with well-defined imaging.
Our light, yet rigid Cerametallic woofer cones feature specially treated aluminum to help better dampen and prevent distortion.
Titanium tweeter with linear travel suspension—trickle-down technology from our flagship Palladium Series—provides an open, natural sound, making you feel as if you’re in the studio with the recording artist or on the set of a film.
Enhanced crossover frequencies offer smoother on-axis and off-axis integration
http://www.klipsch.com/na-en/product...1-ii-overview/
Düşündüğüm fiyatlar
Subwoofer 1.100 TL
Bookshelf 700 TL
Sistem Notu : Bu ilan ikinci el kuralları dahilinde yoruma açıktır.
< Bu mesaj bu kişi tarafından değiştirildi Benzodiazepin -- 2 Mayıs 2011; 18:20:25 >
14 yıl
14 yıl
14 yıl
Ürünler satılmıştır
